Configures MAC Security (MACsec) actor‘s priority for port(s).
mka | Configures MACsec key agreement (MKA) parameters. |
actor-priority | Designates setting the priority advertised during MKA key server election. |
actor-priority | Sets the actor priority value. A lower value denotes higher priority.Range is 0–255 or 0x0–0xFF. Default is 0x10. |
ports | Specifies configuring ports. |
port_list | Lists which ports to configure the actor priority on. |
Default value for actor priority is 0x10.
Important
After enabling MACsec, if you change the actor priority, you must run the configure macsec initialize ports port_list command afterward. Otherwise, the change is not applied.# configure macsec mka actor-priority "0x5" port 13 # configure macsec initialize port 13
# configure macsec mka actor-priority 31 port 14 # configure macsec initialize port 14
This command was first available in ExtremeXOS 30.1.
This command is available on the following platforms.
The MACsec feature requires the installation of the MAC Security feature pack license.Platform | Ports |
ExtremeSwitching 5320 | All ports of all models except stacking ports. |
ExtremeSwitching 5420 | All ports of all models except stacking ports. |
ExtremeSwitching 5520 | All ports, except 5520-VIM-4X and 5520-24X 10G ports |
ExtremeSwitching 5720 | All ports of all models except stacking ports. |
Extreme 7520-48YE-8CE | All front-panel ports. |
